need some advice.
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by Yaka, Oct 19, 2005.
  1. Yaka
    Yaka
    Dec 20, 2000
    1,811
    2
    63
    +147
    ive come across some old but unmarked reinforced glass (1 inch think) one big enough to make a desk, the other big enough for a tv/av stand. i was wondering if somebody could point out a place where i can buy suitable legs, or have a steel frame and constructed to hold the glass.
    any info and help welcome. thanks
  2. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Would be worth getting in touch with any local carpenters or (If you can find one) a blacksmith. Both i'm sure would be willing to build you something. Often the price isn't to outrageous either. Often cheaper than 'factory' produced furniture.
    If you live in the South West I may be able to give you some names.
