need some advice plz
Discussion in 'What Is The Best TV For You?' started by thuglishus, Feb 10, 2014.
  1. thuglishus
    thuglishus
    Nov 1, 2011
    4
  2. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    The Panasonic is £700, you said your budget is £500
  3. thuglishus
    thuglishus
    Nov 1, 2011
    4
    true, but i was looking for opinions on the two tvs i have mentioned above. which i have now narrowed down to 1 because the Panasonic i cant afford..
    cheers
  4. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    Does anybody have a Lg 50PH670V 60PH670V ? | AVForums (the 660 is the same as the 670 without inbuilt wi fi I think)
    LG 50PH660V, No BBC iplayer | AVForums
    There's probably more threads too if you pop the model number in the search box
    FWIW you won't get a better TV for your budget with 5 year warranty. Just take precautions against image retention when breaking it in as this won't be covered by the warranty in many cases
    And the LG is still £90 over budget...
