Need some advice please
Discussion in 'Xbox Forums' started by dean7879, Dec 26, 2006.
  1. dean7879
    dean7879
    i have a belkins router and bridge. can i connect the belkins bridge to xbox 360 so it gets the internet connection from the router?
    if not then i'll probably have to buy thexbox 360 wireless bridge. so if i do that then do i have to get a xbox router to make it work? or will it get the connections of my belkins router?
    below is my Belkin 802.11g
    grateful if u can assist me
    cheers
    [​IMG]
  2. ShadowmanUK
    ShadowmanUK
    Feb 14, 2006
    1,299
    63
    +132
    Yes you can use that. Just follow the instructions you got with it.
  3. dean7879
    dean7879
    nice one
    they are vey dear tho. thats the thing
  4. ShadowmanUK
    ShadowmanUK
    Feb 14, 2006
    1,299
    63
    +132
    Sorry what I mean was, if you've already got a Belkin router and bridge, that will work with the Xbox. As the Bridge is ethernet... so.. it will work with anything with an ethernet port
  5. dean7879
    dean7879
  6. GaryMo
    GaryMo
    Dec 18, 2005
    3,620
    Nr Manchester
    +280
    The USB wireless adaptor you've linked to won't work, you need the official Microsoft USB wireless adaptor.
  7. ShadowmanUK
    ShadowmanUK
    Feb 14, 2006
    1,299
    63
    +132
  8. GaryMo
    GaryMo
    Dec 18, 2005
    3,620
    Nr Manchester
    +280
    Its very confusing.
    Can you list what you have including part numbers?
  9. dean7879
    dean7879
    i have those below. i have a pc upstairs and i use the adaptor to connect to the router connected to my other pc which is downstairs.
    i tryed to put the adaptor in the xbox 360 and it didnt pick up a connection.
    so my question is:if i buy a xbox 360 wireless adaptor, will it connect with my belkin router which is downstairs?
    if not then what do you suggest i do?
    sorry if im not making much sense:cool:
    http://ec2.images-amazon.com/images/P/B00008XYJ6.02._SS500_SCLZZZZZZZ_V55781426_.jpg[img]
    [img]http://ec2.images-amazon.com/images/P/B0006374PK.02._SS500_SCLZZZZZZZ_V36252818_.jpg[img]
  10. GaryMo
    GaryMo
    Dec 18, 2005
    3,620
    Nr Manchester
    +280
    You need a backslash in the end img tag - [/img]
    What is this:
    [​IMG]
    Is it a 4 port wireless router? Model number?
    If so then use the USB adaptor you have on your other PC and buy an official MS wireless adaptor for your Xbox 360.
  11. dean7879
    dean7879
    i have a Belkin 802.11g Wireless Cable/DSL Internet Gateway Router
    http://www.amazon.co.uk/o/ASIN/B00008XYJ6/ref=pd_rvi_gw_3/026-6728052-3455650
    have i got to get this?
    http://www.amazon.co.uk/Max-Wireles...000ENREM0/ref=pd_sbs_ce_2/026-6728052-3455650
    or this? will it definetly pick up the signal from the belkins router?
    http://www.amazon.co.uk/Microsoft-X...000AYTQ7O/ref=pd_sbs_ce_1/026-6728052-3455650
  12. GaryMo
    GaryMo
    Dec 18, 2005
    3,620
    Nr Manchester
    +280
    I'm not sure on that router at all but if you go by customer reviews on Amazon then its utter crap.
    This is the wireless adaptor you want for your 360 - Clicky
  13. dean7879
    dean7879
    its not crap. ive had it for months and havent had one single problem with it.
    yeh i know about the xbox adaptor. i want to buy it but i just need a confirmation off somebody that it will pick up the signal from my belkin router.
    if not then wat router will work with it!:D
  14. GaryMo
    GaryMo
    Dec 18, 2005
    3,620
    Nr Manchester
    +280
    I've used an official MS wireless adaptor with my Belkin router without problem though the router wasn't the same model.
  15. dean7879
    dean7879
    i'll give it a crack anyway
    do u know what this guy means?
    I have my 360 plugged in to my PC, which then uses a wireless connection to a router in another room, which then connects to my cable modem. It took a bit of faffing about but it works fine
    The benefit of this is that I saved myself ~£60 and the ethernet cable came in the box along with the 360 .
