Hi steebu . . . perhaps you can say why this height is needed....and what you've tried in the past that failed.
+ Is this for carrying about? -or- for use near a car, for example..... Is this a quick-set-up, or one where you will be staying-put?
You may have to give us some idea of the Budget, too.
I'm amazed that most tripods are so short . . . most incapable of achieving "eye-height" unless the target human is seated, or a child.
Professional ones are taller, but heavier and selling in small numbers ( plus the "Pro" tag) raises the price considerably. I have a Manfrotto pro that is almost 6' - but that weighs as much as a small child and is rarely used.... Esp. now that most cameras+camcorders have active stability built-in.
Have you considered a jib ? - placed on a modestly robust tripod, it will easily reach yr target height - but monitoring the view then becomes an issue.
Cheers.
