Need remote for Sherwood RVD6095RDS AV Amp
Discussion in 'Home Cinema Control & Remote Controls' started by Jamp, Dec 7, 2003.
  1. Jamp
    Jamp
    Aug 8, 2003
    76
    Sheffield/N Wales/Isle of Man
    I bought my RVD-6095RDS AV amp in Richer Sounds' open box sale as a graded item, hence it has no remote or manual.
    Getting grumpy having to scrabble around on the floor pressing buttons, so I'm after a remote for it. Is it possible to buy an original from Sherwood or some other source? Or should I get an all in one?
    With a budget of £60 say, which all in one would I be best to go for?
    Other gear includes:
    Pan TX28PS1 TV
    Tosh SD330E DVD
    LG LV720 VCR
    (I have the original remotes for these)
    Planned for the future:
    Freeview box, not sure which.
    MiniDisc deck, probably Sony.
    Would a Maplin Learning 8-Way E-Pilot Remote Control do the trick? Seems good value at £30.
    Would a Cambridge Audio model from Richers do the job any better?
    What makes a Kameleon worth £70 other than it looking nice?
    Cheers,
    Ben :hiya:
