need recommendations asap... marantz sr4400 vs. yamaha rxv350
Discussion in 'AV Receivers & Amplifiers' started by doorknob2k1, Dec 23, 2004.
Tags:
  1. doorknob2k1
    doorknob2k1
    hi there!
    christmas sale is on... im caught between two receivers...
    yamaha rx-v350 = Philippine Peso 12600 (US$ 225)
    vs.
    marantz sr4400 = Philippine Peso 13995 (US$ 250)
    i need your kind recommendations asap. thanks! =)
  2. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
    It mainly depends on what you use mostly music or movies. The marantz will be the best music machine while the Yamaha the better with movies. Which ever you decide on will be a good into to home cinema.
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,794
    London
    +1,080
    Welcome to the forums :thumbsup:
    Out of those two I would probably lean towards the Marantz 4400. Good for movies and music :)
  4. doorknob2k1
    doorknob2k1
    concert dvds = 80%
    movies = 20 %
    so... i guess i'll be using it mostly for music.
  5. Dfour
    Dfour
    Jan 19, 2004
    4,088
    71
    Bracknell
    +86
    Then the marantz is possibly your best bet. Can you stretch to getting a 5400 as it uses better dac's (192/24 v's 96/24) then the 4400 and has more power.
  6. doorknob2k1
    doorknob2k1
    my budget would only allow me to get either of the two...
    and this is my first receiver if ever... im new to this.
    im looking at pairing it with gale speakers
    (http://www.gale.co.uk/htpackage4.html)
    which also is on christmas promo sale right now
    here in the philippines... any thoughts on this?
  7. Tejstar
    Tejstar
    Dec 4, 2002
    22,794
    London
    +1,080
    Couldn't get the link to work :confused:
  8. Mandel
    Mandel
    Both my systems are Gale Speakers + Yamaha RX-V?40 amps. Pair together rather nicely!
  9. doorknob2k1
    doorknob2k1
    which gale speaker set are they? series 30?
  10. doorknob2k1
    doorknob2k1
    finally got the marantz sr4400 last friday... just wanted to share. :)
    are the yamaha nsp106 speaker set okay? they're the only set i could afford for now @ PhP 10,000 (around US$180). :confused:
  11. Diamond
    Diamond
    Marantz must be nice.. Any other speaker options, Wharfedale etc non-hifimakers? (non-receiver makers)
  12. doorknob2k1
    doorknob2k1
    hmmm... i saw wharfedale's diamond8 and diamond9 series... but for my current budget it would only allow me to get a pair of front speakers. (eg. diamond 8.3 or diamond 9.4) :confused:
    i am dying to experience multi channel sound in my own room. :(
  13. Diamond
    Diamond
    DON'T ruin it now, as you've got a great amp. Speakers are the most important piece of the whole set. My advice is forget the 8-series, forget the floorstanders. Get a pair of 9.2s or 9.1s first, and buy 9.0s or 9.1s or 9.SRs for surrounds when you have the money. For center get a matching speaker, third 9.2 for example.
    2x 9.2 or 2x 9.1 for start.
    In future:
    3x 9.2 + 2x 9.1
    5x 9.1
    3x 9.1 + 2x 9.0
    These go low for small speakers, with those 9.4 or 8.3 you get more boominess. You can ask for discounts on those. But please do as you wish...
  14. doorknob2k1
    doorknob2k1
    thanks for your advice. i really appreciate it. :)
    will visit shops and audition these 9.xs... and maybe ask for discounts.
    what about floor stands?... don't they cost as much as another pair of bookshelfs? :confused:
    do u have a picture of your five 9.1s? i'd like to see how u set it up. :)
  15. Diamond
    Diamond
    You're welcome. :)
    I don't mean 9.4 is bad, it just needs a mediocre or big room, or placement that is 0,5 to 1,0m from the wall. Bookshelves are always cheaper, because the bigger enclosure is more expensive. Of course the stands cost then.. But you can build them, DIY. Your room size?
    If you compare same price floorstanders and bookshelves, the latter is usually better. More quality for the price. They don't extend as low, but sound is finer, the sub is needed for both with movies, music don't necessarily need one.
    If you have the room and space, pair of 9.4s or 9.5s would be nice, 9.2 is equal though with lower price. Close to wall you should maybe stuff the ports, I'm just experienting with that. So the bass freqs don't come too loud. This is just my setup, in a bigger/better acoustics room I'd have bigger speaker for fronts. 9.1 or 9.sr or 9.dfs do well in the back. Three speakers with identical/similar drivers in the front is important, 9.2 would go well with 9.5s! The center is not always necessary though. If you like music more, then invest the most in two mains.
    [​IMG]
    The stands are Apollos, A1/9 model.
    [​IMG]
    [​IMG]
    SVS sub. :)
    (The links don't always work, try later then plz. )
  16. doorknob2k1
    doorknob2k1
    hmmm... interesting thoughts. thanks! :)
    the room's quite small... http://hometheaterhifi.com/forum/showthread.php?t=1623
    i moved my bed in this room a few weeks ago... (knowing that its gonna take a few months before i could really turn this into a dedicated av room)... i noticed a decrease in the echoes... must be the mattress. :rolleyes:
    haven't been able to see your pictures... it won't load up. :(
