need recommendation
Discussion in 'AV Receivers & Amplifiers' started by kelvinblade, Sep 5, 2003.
  1. kelvinblade
    kelvinblade
    i'm planning to get a pair of minipods for my computer.
    what amplifier should i get?
  2. kelvinblade
    kelvinblade
    anyone?
  3. nathan_silly
    nathan_silly
    Anything decent really- good stereo integrated amps- Rotel, NAD.
    Do you want stereo only or multi-channel audio? (Pro-Logic/DD/DTS)
  4. kelvinblade
    kelvinblade
    i want multi channel but for now i'm just gonna have two speakers
    rotel rsx 1055 <- SO EXPENSIVE....
    how is the yamaha v640 / v540 ?
  5. nathan_silly
    nathan_silly
    Yamaha's are OK, should do for a PC setup. Go for the 640- even though the 540 is good enough- the lower end Yamaha's don't tend to cope well with low impedance speakers. The Minipods are 4 Ohm nominal, so could be a tricky load with lower quality amps.
    Regarding the Rotel; I was talking about stereo integrated amps. These are quite affordable. The Rotel AV amps are quite expensive, as you've found out.
  6. kelvinblade
    kelvinblade
    do i need an amp or a receiver between my PC and the speakers?
    can you recommend some under $400 both stereo and multi??
    i don't think i know what i'm looking for...
  7. nathan_silly
    nathan_silly
    Yeah you'll need a AV Amp between the PC & speakers. There are lots of models to choose from, IMO Yamaha are probably the best starter AV amps.
    Are you from the US?)- www.avsforum.com is a better place- as that site is mainly for the americans.
