They are low depth on-wall speakers for the effect channels and differs in design to normal direct radiating speakers so you get more dispersed soundfield which spreads the sounds more and be less directional due to two tweeters firing both directions. I feel this is important if you going to have speakers close to you which is far from ideal and here the bipole design can help. These are on sale as soon discontinued and normally 499£/pair so great deal! Full specs here:
You won’t better the Monitor Audio Silver FX loudspeaker for perfectly discreet side and rear channels in a home theatre system.
www.monitoraudio.com
If you can push the speakers forward 20-30cm then some slimmer floorstanders like Silver 200 would work. So moving the tv/av-unit more to left same as the couch so you can spread the main speakers more apart, but i wouldn´t want to keep the left main speaker directly in corner so push it forward some.
The Polk Signature range is budget range from US. You can get better system for 2500£. Let`s put one example that will be good step up from Polks and you get real wood veneer finish also (walnut, rosenut) or gloss black (cost bit more) or satin white. This would include compact size center channel, however that doesn´t mean you should put it inside the unit. Buy the floor tv stand i linked in post #7, the one without the middle glass base, so it goes behind and under your av-unit and offers height adjustable tv stand. That allows you to place the center channel on top of the unit at front below tv.
The award winning Silver 200 elevates performance to a new level delivering the best possible sound. Whether from movies or your favourite music, with the Silver Series of technologically advanced loudspeakers you can be sure of a quality so lifelike that it takes you to the heart of the...
petertyson.co.uk
Monitor Audio’s Silver C150 dialogue speaker is designed primarily to partner the smaller stand-mounts and floorstanders in the range, being carefully voiced to complement the timbre and balance of the Silver 50 and Silver 200 models; guaranteeing consistent sonic character.
petertyson.co.uk
Monitor Audio has all your rear and side channel requirements covered with the Silver FX, loudspeakers specially designed for 5.1 and 7.1 systems and featuring Monitor Audio’s advanced technology.
petertyson.co.uk
Upgrade to this Denon high-power 9.2ch 8K AV Amplifier. Ideal for bigger rooms with it's 9 built-in Amplifiers. With IMAX Enhanced and full 4K/8K HDMI video support, the 'X3700 is a big step forward.
petertyson.co.uk
1187£ speakers and 1150£ receiver = 2337£. Now if you contact PT and ask them to make you "package deal" from these products you will likely see better pricing. It´s going to be quite tight to get good subwoofer within your budget so this might still be too much. For subwoofer example UK made BK as new grade-b satin black for 440£ shipped. Read the AVForums review for it if intrested.
Find many great new & used options and get the best deals for BK Electronics Platinum P12-300SB-PR Subwoofer - Black at the best online prices at eBay! Free delivery for many products!
www.ebay.co.uk
Or if you want something little better with longer warranty and more modern design then Monoprice 10 THX which is best performing sub in 500£ region.
***Please notice: The Monolith™ THX® certified subwoofer will be delivered with an EU Plug.*** The Monolith™ THX® certified subwoofer sets the standard for bass output, low distortion, and affordability. With chest thumping bass that plays down to well under 20Hz, the Monolith subwoofer...
www.monoprice.uk
The way to lower price of speakers to have high quality subwoofers within 2500£ while keeping the better Denon model would be to go with Silver 50 or Silver 100 bookshelf speakers for front mains. However you require speaker stands so roughly 60-100£ for those.
The ultra-compact Silver 50 introduces a completely new version of Monitor Audio’s special 5¼-inch C-CAM bass/mid-range drive unit, creating the most diminutive bookshelf model ever to appear in the line-up.
petertyson.co.uk
The Silver 100 is a serious audiophile speaker capable of producing remarkable resolution, from the most intricate musical scores to the loudest rock concert, with superlative ease.
petertyson.co.uk
Tell me what you think of these and also tell me can you visit your local store to go listen speakers before buying?
