Need pronto 940 cable?
grant1sc
Established Member
Joined
Dec 29, 2003
Messages
356
Reaction score
23
Points
92
Age
42
Location
Stafforshire
Where is the best place for me to get a pronto cable to connect to my pc? Cheers,
Lee
They have the usb cable for the 950, im usure how well this will work? any advice appreciated? thanks,
Lee
Won't work. 950 uses USB whereas 940 is serial to minijack. Completely different cable.
Yea, im not great with making things but its lookin like the only option. I may have to take a trip 2 maplins.
I might be making one this weekend 'cos I can't find mine. I've got three spare serial cables so maybe I can botch another one together...
Mike.
Mike,
Can you go into a little more detail as to how I make one?
I may be tempted to try if I was a little clearer. Cheers
Lee
grant1sc
Get yourself a cable with a 9 pin female serial connection on one end.
Chop off whatever is on the other end.
Get yourself a multimeter and check the pin outs to see which colour wire refers to which pin out (hole on the serial connector - they will be marked 1-9 on the connector).
Next check out this link
http://www.prontoedit.com/download/prontocable.zip
to get a diagram of which pins refer to which pole on the new 3.5mm jack plug.
Solder the relevant wires to the correct poles on the new jack plug.
and that is it.
BTW, you only need a 3pole jack plug NOT 4 (which are very difficult to come by). If you notice two of the poles are connected together hence only 3 being needed.
Sorry if this sounds stupid, do the jack plugs come with the relevant bits showing or do I have to remove the plastic case? Thanks,
Lee
send me a stamped addressed jiffy envelope and i'll send you one.PM me and i'll give you my address
Bob,
many thanks for your kind gesture but i have just purchased one. Thanks once again,
Lee
LG G4 OLED Best Picture Settings Out Of The Box - Filmmaker Mode!
Back
