need original nW-HD5 sample tracks please
Discussion in 'Headphones, Earphones & Portable Music' started by daveey, Aug 21, 2005.
  1. daveey
    daveey
    Aug 21, 2005
    101
    +4
    hello,
    please anyone still have original sony NW-HD5 tracks as pre installed on new unit, having to take mine back and factory defaults does not re install the sample songs.
    please please take 10 mins to email lthem to me PLEASE :lease:
    daveeyt@lycos.co.uk
    :lease:
    :lease:
  2. johann1979
    johann1979
    Feb 18, 2005
    857
    19
    London
    I've deleted mine Daveey, so I am sorry I can't help - I did however think I should tell you not to worry about them if you are taking your HD5 back. For a start I can almost bet on it that they wouldn't check for them when you take it back and as the machine will be refurbished before sale to another customer (depending on your circumstances), it will all get put back on. :)
  3. HMHB
    HMHB
    Nov 11, 2001
    26,630
    Nottinghamshire
    +5,331
    Yes, as Johann says, I can't imagine anyone would check it when you take it back - and even if they do they can't reject it for that reason.
  4. DreamNshadow
    DreamNshadow
    Okay, I'm kind of mad. I didn't get any screen cover, or sample songs on both my HD5's. I hope it's just the U.S. versions that are like this.
