Need one of these C16 Irewireable IEC's.
Discussion in 'Cables & Switches' started by Kane D Williams, Jan 1, 2004.
  1. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +10
    Anyone know if Maplin sell these? I can't find them on their website, but... If anyone has one I could buy, I will pay £2.50 inc P&P. ? I refuse to pay more for the P&P than for the actual item from companies like RS etc.
  2. Jason S
    Jason S
  3. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,105
    Portsmouth / Middle East
    +77
    Yes maplins do have them. I used the right angle one to get the sub closer to the wall.
  4. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +10
    Thing is, I had looked at CPC and theirs is the same as those sold at RS, but it is £6.89 with P&P/VAT! This is silly, so I will simply pop down to Maplin tomorrow and pick one up. Thanks.
  5. Jason S
    Jason S
    The only ones I can find in Maplin's are the type that fit into those pictured, i.e, the usual bit that fits into the equipment. I can't find any of the picture type plugs.
    A part number would be handy if you get one, as it's easier for me to visit them than order too.
