CaptGadget
Established Member
- Joined
- Jan 21, 2009
- Messages
- 818
- Reaction score
- 43
- Points
- 192
I have a Logitech Z5400 5.1 kit which i used for my bedroom (PC/TV) the speaker cable which came with it is on its way out now...
i am looking to replace the cable on the whole kit with something as good or better if possible for reasonable price but i cannot seem to find anything decent, could someone take a look at the tech spec and tell me what kind of cable i would need please?
front 3 speakers would need max :- 6-7M cable
rear 2 will need about 12M
TECH SPEC :-
Specification:
PC multimedia home theatre speaker system
Speaker Type - Active
Nominal Output Power (Total) - 310 Watt
Max (RMS) Output Power (Total) - 620 Watt
Response Bandwidth 35 - 20000 Hz
Input Impedance - 9.5 kOhm
Signal-To-Noise Ratio - 99 dB
Output Level (1m) - 103 dB
THX certified - Yes
Audio Amplifier - Integrated
Built-in Decoders - Dolby Pro Logic II, DTS 96/24, Dolby Digital, DTS decoder
Controls - Mute, volume
Detachable Grilles - Yes
Speakers Included:
2 x right/left channel speaker - 38 Watt
2 x right/left rear channel speaker - 38 Watt
1 x centre channel speaker - 42 Watt
1 x subwoofer - 2-way - 116 Watt - wired
Driver Details:
Satellite speaker : 1 x full-range driver - 2.5" aluminium
Subwoofer : 1 x subwoofer driver - 6.5"
Connections:
1 x digital 5.1 channel audio line-in
1 x audio line-in
2 x digital audio input (optical)
1 x digital audio input (coaxial)
any help would be much appreciated...
cheers guys..
TECH SPEC :-
Specification:
THX certified - Yes
Speakers Included:
Driver Details:
Connections:
1 x audio line-in
cheers guys..
