Question Need more Speaker Cable for Tannoy TFX. Which type to get?
Discussion in 'Home Cinema Buying & Building' started by Rikachu, Jun 20, 2015.
  1. Rikachu
    Rikachu
    Aug 30, 2008
    333
    London
    +48
  2. Roohster
    Roohster
    Jul 1, 2004
    4,712
    7
    Derbyshire
    +5,806
    Either of the cables you linked to should do the job as long as they're a similar gauge as the existing cable.
  3. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    2.5mm is usually the minimum we recommend Van damme Blue is popular but we use this
    2 5mm Pro Speaker cable
    Though a 50M drum may be too long for your use
  4. Rikachu
    Rikachu
    Aug 30, 2008
    333
    London
    +48
    Ended up grabbing the 6x3mm cable.
    The 4x2mm cable had next to no copper in there!
    Thanks all, problem solved.
