need more sata ports - recommendations?
T0rNaDo
so im needing another two sata ports.
available ports are..
1 x pci-e 4x slot
2x pci-e 1x slot
2 x pci slots.
anyone use any expansion cards for extra sata's ports and have any recommendations..
ideally it would be nice for them to run at the 6gb/s speed.
cheers.
Simon D
T0rNaDo
hi simon, i did look on amazon last night as it goes.
and could see there a many on there, at various prices and
a few i looked at didn't state windows 10 was a supported o/s
scan has got back to me and linked to one they sell
funny enough its the brand you have said..
pricey thou, but if its better then the cheaper ones on amazon ,
then i guess its worth paying the extra.?
also il plug my dvrw into to and use the 6 on the mobo for the 2 sdd's and two caddies.
Simon D
Yes that the same one that I had.
I had the same problem I only had 6 sata ports on the motherboard which I was using for my SDD's/hard drives at the time.
So I was forced to use the card for my two optical drives.
I would check the manual for your motherboard first to confirm that you do not lose any sata ports if you use a pci-e 4x or 1x slot. You should be OK for 1x slot.
T0rNaDo
i see nothing in the online manual about losing sata ports if using the pcie slots.
so should be ok.
mtenga
If you are still looking this card is PCI and has worked fine for me over a couple of years with Win10.
Amazon product
T0rNaDo
hey thanks for the reply.
i think il futureproof myself a little by going with a pci-e card.
incase my next motherboard turns out not to have pci slots.
thanks for the post and link :)
goingoingong
1 x pci-e 4x slot
2x pci-e 1x slot
2 x pci slots.
cheers.
If you are still looking I've been using this one for over a year without problems.
PCI-E card and has 2 ports without using a driver or 4 ports when using driver.
Amazon product
v2 API
Some of the old Dell 9211-4i server cards that come up on ebay are rock solid. As long as they are flashed in IT mode. You just need a mini sas forward breakout cable and you're good to go. Total cost would be around 50 quid. Far more reliable than some of the cheap Chinese tat floating about on amazon.
Oculus Quest 2 VR headset + Rotel A14 MkII Amp Reviews & Best of the Month
