Need more length(speaker cable that is!!!)
Discussion in 'Home Cinema Speakers' started by peacemakerdan, Oct 6, 2005.
  1. peacemakerdan
    peacemakerdan
    Sep 28, 2005
    61
    Just finished conversion of garage into home cinema with surround 5.1.
    Unfortunately I need to extend 2 of the speaker cables (badly planned I know).
    My question is simply what is the best way of doing this as I can`t access the cables to re-route.
    Will simply splicing them be ok or should I solder or can you buy connector clips??
    Many Thanks
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    That should be ok and cover any gaps with electric tape to make sure there not exposed.
  3. Troon
    Troon
    Apr 28, 2005
    151
    Definitely solder, unless you have a really good crimping tool. The aim is to minimize joint electrical resistance and to provide a reliable robust mechanical joint.
