need longer component cable ot adapter to reach projector ?
jamieuk23
Hi as you no the standard cables that come with the 360 arnt that long.. my projector is at the top of a 8ft celing and I need to reach it so I can play my 360 on it.
cable is far to short... do you no a device which will act like a extension ??
links to divice would be perfect thanks !!
:thumbsup:
steel_kelly
you can get a component lead in maplin for about 20 notes that will do the trick just use a coupler to connect the xbox lead to the longer component lead. your welcome
Daipac
Tetlee said:
tvcables.co.uk are a great company for this type of thing. These are what I use for hooking up to my projector:
15metre component cable http://www.tvcables.co.uk/cgi-bin/tvcables/CP004.html
Joined to the Xbox360 component with one of these chappies http://www.tvcables.co.uk/cgi-bin/tvcables/AD013.html
Works perfect, they do various lengths of component cable so just get the length you need.
I am looking to use something similar to this to connect my Xbox 360 upstairs in my bedroom to the TV in the living room downstairs.
When using a component cable around 10m in length, will there be a loss in PQ using this method ?
jamieuk23
longer the cable the more degrade in PQ. just buy a exspensive cable. you wont eb able to tell uless you put your face up to the screen
jamieuk23
cheers dude !! thats just what I wanted !!
he shoots >>>>>>>>> he scores !!
:thumbsup:
