need kodak easyshare for dx 3600
Discussion in 'Photography Forums' started by Tafsir, Feb 24, 2003.
  1. Tafsir
    Tafsir
    Jul 9, 2002
    1,209
    48
    uk
    +97
    can anybody help me find kodak easyshare for dx 3600
    so i can hook the camera to the pc
    Thanks Tafsir
  2. minimad
    minimad
    Tafsir
    Do you need this for a specific purpose?
    My recommendation - and one that will save batteries on the camera - is to get a USB/Parallel Card Reader. These can be bought for as little as 30 quid - permanently connect to the PC (or laptop!) and will take the Compact Flash from the Kodak.
    I have an old DC 265 and got fed up with killing batteries trying to transfer files.
    HTH
    Collin
  3. Tafsir
    Tafsir
    Jul 9, 2002
    1,209
    48
    uk
    +97
    minimad
    i am looking for the software that comes with the camera
    did a full format on the pc, & cannot find the cd software to put back on the pc,
    my pc cannot find the camera when it is looking for it
    i used to use the docker station to transfer the images to the pc
    battery life seems fine on my camera at the moment
    Tafsir
  4. jim.rae
    jim.rae
    Go to the Kodak website and see if you can download it from there.
    I had to do that when I changed my computer as the software that came with the camera wasn't compatible with Windows XP.
    Mind you I have broadband and it downloaded pretty quickly - depends on your modem I suppose...
  5. Tafsir
    Tafsir
    Jul 9, 2002
    1,209
    48
    uk
    +97
    thanks for the help guys
    got it sorted now
    Tafsir:)
