Need info please...
Discussion in 'AV Receivers & Amplifiers' started by graphicsgod, Nov 6, 2005.
  1. graphicsgod
    graphicsgod
    I need some advice.
    I have just lost my Aiwa AV-D58 Receiver :(. It was my first SS system and hate to see it go. I'd like to fix it, but I don't think it's worth it. It stoped outputting sound, or at least after a few seconds of sound it would go silent. First started to the FM/AM, then the CD input, and then finally the digital went out. All within a year, this year to be exact. Had it for about ten years. Not sure what happened :(. I even checked the inside, no dust or burn marks of any kind :confused:.
    So now I'm in need of a new reciever ASAP! So what reciever will work with my previous setup?!? All 5 speakers have 80W and 8 omes of power. Sub is 12V 60Hz. I don't want to spend a fortune. Just need a good reciever between $150-400, no more... no less. I was thinking about a Yamaha, since I've heard good things about em.
    What do you guys think I should do or buy?!?
    Rob
  2. smallmanongn
    smallmanongn
    This forum is largely UK/European so any recommendations aren't likely to mean much as the US is probably going to have different models to what we have.
