Need info on aspect ratio for AE100E
Discussion in 'Projectors, Screens & Video Processors' started by Amelia, Jul 16, 2002.
  1. Amelia
    Amelia
    I just got my AE100E and tried it out last night.
    I Noticed when I set the aspect ratio to 16:9 for DVD the image was smaller than the full screen. I am not talking about the band on the top and bottom for ultra wide screen. I am talking about black band all the way round including sides. I noticed if I select the zoom it looks fine.
    Is this normal?
    PS: The DVD player is connected via S-Video
    Best Regards
    Amelia
  2. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    yes this is normal i had to zoom the picure up a bit so it would fit the screen properly
  3. Amelia
    Amelia
    This is what I mean. I am not talking about the zoom on the lens.
    When pressing the aspect ratio button if 16:9 is selected from a DVD source (using S-Video), this is the result
    [​IMG]
    When pressing the aspect ratio button if ZOOM is selected from a DVD source (using S-Video), this is the result
    [​IMG]
    I would have thought if 16:9 was selected it would use the full image size.
    Kind Regards
    Amelia
  4. magking
    magking
    Jan 6, 2001
    380
    Norway
    Just a simple question.
    Is your DVD player set to 16:9?
    You have to select that you have a 16:9 display.
  5. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Posting what make/model of dvd player may help too ???
  6. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    Yes I noticed the same Amelia, a narrow black band at each side about 2 inches wide but only when I set the PJ to wide 600 (I think it was), but when I put it back to normal 16.9 it was fine.
    I personally dont like the Zoom but I`m thinking it might be usefull with some of my letterbox copies.
    I sugest you have a good tinker with all the different settings and then you`ll see the changes you Like or disslike.
    I`m afraid I don`t get the time to do too much tinkering with the PJ at the moment and when I have done something it`s difficult to remember just what I did untill I get back on it. Bear in mind I am useing the Pro v too which has a lot of settings of it`s own too
  7. Amelia
    Amelia
    I guess I may have asked the question too soon. I have only used the pj for two hours, when I first got it. Now its packed up again untill the room wiring, painting and electrics are completed.
    In any case I will have a bit of a tinker once I have it set up again.
    Best Regards
    Amelia
  8. Walter mitty
    Walter mitty
    Aug 1, 2001
    232
    19
    Shropshire
    Hello again,
    With a second look at the problem you describe and looking at the photos, I reckon it`s fine you need to set it to 16.9 then fill the screen by moveing the Pj and adjusting the zoom ring.
    I dont think you will need the zoom function ie/from the remote control unless your watching a letterbox type films.
    I thought originally it was a thinner band which totally goes when you change the settings, that you were talking about
  9. Amelia
    Amelia
    OK I finally got the PJ back up again and magking you are 100% correct, I didn't change the DVD set-up to 16:9 :blush:
    :blush: Whoops :blush:
    Sorry for the brain dead post
    Regards
    Amelia
