need help!!!!!!!!!!!!!!
Discussion in 'Movie Forum' started by Desperado, Apr 20, 2002.
  1. Desperado
    Desperado
    iam about to purchase a DVD player from the US (Phillips/Magnavox DVD611AT DVD)
    now iam wondering will it play here in the uk ??
    could someone please give me a answer!!!!!!
    thank u !!!!!!!!!!!!!!!!!!!!
    desperado
  2. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    not without a stepdown converter/power supply
    unless its a dual voltage player ie 110 / 240 volts
  3. Desperado
    Desperado
    where can i get that ? is it expensive?
  4. bh
    bh
    Jul 14, 2000
    397
    Lost (no GPS here)!
    Try:
    Keene
    "Allows USA electrical equipment (110/120V supply required) to be powered from the UK (220/240V) mains. Simply plug in the wall step-down transformer. Ideal for radios, Hi-Fi systems and other small appliances (not exceeding 30VA load). [USM30]
    Costs £24.99
    Job done
  5. Desperado
    Desperado
    thanks a lot for your help!!!!!!!!!
  6. bh
    bh
    Jul 14, 2000
    397
    Lost (no GPS here)!
    Good luck.
    Let us know how you get on.
    bh
  7. Desperado
    Desperado
    thanks again !!!!!!!!
    yes sure i will !!!!!!!!!
