need help with xcard resolution settings
Discussion in 'Desktop & Laptop Computers Forum' started by xappie, Mar 6, 2005.
  1. xappie
    xappie
    Hi all
    I have been trying to find the registry settings to enable my Xcard to output at 800x600 on the VGA connection, for viewing on my Hyundai L90D+ LCD panel but I am not having much luck.
    Can anyone help? My LCD will display up to 1280x1024, but the only setting in the Xcard software that works is 720x480p at 60HZ - which my LCD reports as 640x480. I am really just looking for a way to get a higher resolution displayed here... whats the magic trick?
    Any advice is appreciated!
    :lease:
  2. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,497
    South Derbyshire
    +205
  3. xappie
    xappie
    Yes, I have read through that post several times, but I don't see any solid instructions on how to generate those values that go in the registry. None of the posts include the values for either 800x600 or 1024x768 etc.
  4. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,497
    South Derbyshire
    +205
    Those settings are derived from powerstrip.
    So install it and set the resolution and then use the values Powerstrip gives you.
