Need help with the CyberHome AD-L 528 plz
Discussion in 'Blu-ray & DVD Players & Recorders' started by MysticKiller, Jul 24, 2004.
  1. MysticKiller
    MysticKiller
    Hi, i purchased this dvd player from richersounds about a year ago, now a days it reads everything fine, but sometimes (specially in MP3's), it recognize's the disk, plays for a while, and then crashs, just freeze's, i turn the power off, and then back on, and then it just keeps crashing, not even playing it at all, and another thing is, i made a picture dvd, using Ulead software, i put it on a Bulkpaq DVD+RW which works fine in there, i made another dvd using the same program, except i put all the video's on it of my holiday, and on the same type of disk, but for some reason, it will not read it, please help, thanks!
  2. WILD9
    WILD9
    Mar 12, 2003
    157
    Cheltenham
    +6
    i had a 528 and after about a year and a half it did the same as yours, i just got a new player the 528 was good at the time but theres plenty of good cheap players these days. As for the videos on the disk i believe it would have to be burnt as a dvd movie for it to play rather than a series of video files its not the same as a picture cd.
