Need Help with [see the future]
BlackCammeh
well when i bought it the add on murgo gives you the 2 quests as normal,
my friend says after the first 2 quests hes ment to give you access to the colluseeum? if so, i havnt been given it yet.. i think my save might be glitched??
can anyone shed some light on my situation please:confused:
P.S sorry if spelling is off.
Cam
count zero
After the second (cursed skull) quest you get the "see the future" quest, which is basically a cut scene. It isn't until after this that Murgo gives you the colleseum model.
The "see the future" quest will not appear until after you have reached one of the three endings as the cut scene sort of follows on.
cheers, count
BlackCammeh
All done now, found out i needed to finish the main story to get the next piece (The Spire Statue) then i got the colleseum model thanks for the help anyways guys
BlackCammeh
Can a mod please close thred. or if i have to can you tell me how as i dont know :thumbsdow
