need help with projector settings
Discussion in 'Projectors, Screens & Video Processors' started by pilot, Sep 30, 2003.
  1. pilot
    pilot
    tried to set up my new Panny AE200 last night.
    SKY TV seems to work fine - no problems at all. however, cant get any colour output from the DVD player.
    i am using a SCART for the SKY to the projector - i get colour - no probs.
    I am using S Video out from DVD player and SCART into projector - no colour.
    what could be the reason? anyone help me pls !!! i think its something to do with the dvd player? its a pioneer. it works fine with a normal TV though.
    thx !!
  2. CooperUK
    CooperUK
    Jun 30, 2003
    2,180
    Hampshire
    +295
    I know it sounds daft, but wiggle the lead at the PJ end, gently though!
    Or, failing that, take it out and replug it in.
    Same happened to my ae100 the other day and I checked every setting on the DVD and PJ before realising that the lead had worked loose at the PJ end.
    Have you checked that you are on the right input setting on the PJ when using the S-V lead?
    Hope that helps,
    Coop
  3. pilot
    pilot
    ok thanks
    i will try that this evening. but something tells me it wont work !! ?? i shall let you know 2nite if thats worked or not
  4. gothmog
    gothmog
    Dec 17, 2002
    204
    16
    Sunny Shipley
    Are you sure that the AE200 accepts s-video on the SCART?
    It would be surprising as it also has a seperate s-video socket ;)
    -- Jon
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,150
    +2,968
    Yes it sounds like it is looking at composite pin on the scart at PJ. This is carrying only b+w info....hence no colour.......Set your DVD to output composite on scart and I bet you get colour on pj.
    As Jon suggests using the s-video socket might be another solution
    Gordon
  6. pilot
    pilot
    ok cool, will try all of the above this evening and will let you know the outcome.
    thanks a lot guys !!
  7. Jonathan100
    Jonathan100
    The pt-ae200 does not support s-video over scart. The scart lead can take composite or RGB. If you want s-video you must use an s-video lead. I would not reccomend composite, so either set the dvd to rgb or buy an s-video lead.
  8. pilot
    pilot
    cheers guys
    tried the rgb setting on the dvd but to no avail. I think i will go and get an S-video cable at the weekend. seems like the best solution.
    amazing quality of the projector though. i am most impressed !
