Need Help With Prog Scan
Discussion in 'Projectors, Screens & Video Processors' started by PAUL RODGERS, Sep 14, 2003.
  1. PAUL RODGERS
    PAUL RODGERS
    Sep 14, 2003
    159
    manchester
    PROBLEM
    JUST SPENT £660 ON A DENON DVD2900 TO GO WITH MY PLASMA SCREEN L&GMZ42PZ17.
    I KNOW IT IS NOT THE BEST PLASMA BUT FOR £2000 COULD NOT REFUSE.
    WHEN I ACTIVATE PAL PROGRESSIVE THE PICTURE BECOMES JUMPY.THEREFORE THERE HAS TO BE A COMPATIBILITY ISSUE I THINK.
    CAN I BUY OR SHOULD I BUY A DEVICE TO CONVERT THE PICTURE INTO PAL PROGRESSIVE SCAN.IF SO WHAT IS RECOMMENDED AND WHERE CAN I BUY ONE FROM.::lesson:
  2. Warpaint
    Warpaint
    Jul 26, 2003
    589
    28
    Edinburgh
    +61
    If the Denon Prog Scan picture is jumpy then another Prog Scan processor will probably be jumpy too.
    If your Plasma has a 15 pin VGA input then this might be compatible.
    I believe that you can get a converter from Component out to 15 pin VGA in.
