Need help with PES4
Discussion in 'Xbox Forums' started by Dogma21, May 9, 2005.
  1. Dogma21
    Dogma21
    Feb 4, 2005
    381
    Leeds
    +16
    Can someone help me.
    When I'm playing PES4 online I don't know how to start a game by inviting a friend.
    I know how to invite them and I get a message back to say invitation accepted but I don't know what to do next to start the game.
    I'm doing this from create a match and selecting a friend from the list, is this correct??
    Please help it is really starting to :censored: annoy me.
    :lease: :confused:
  2. Dogma21
    Dogma21
    Feb 4, 2005
    381
    Leeds
    +16
    anybody.....please.....
    It doesn't say in the instructions and it doesn't seem that obvious from the on screen menu.
    :lease:
  3. harrist0
    harrist0
    Feb 10, 2005
    291
    16
    London
    normally with the invite acceted message it has another line saying join game, however, as you said you are playing a friend it might be that you are not able to connect with them. Huge problems with this in the pse4 league. If you are able to connect straight to your modem without the use with a router this usually helps. Have you ever player this friend before?
  4. finlab
    finlab
    Jul 23, 2002
    118
    Aberdeen
    I assume you mean for the xbox.
    If its pc then I can help
  5. Dogma21
    Dogma21
    Feb 4, 2005
    381
    Leeds
    +16
    Yes I do mean the xbox version.
    I do not see the join game message, when a friend accepts my invite.
    I do see it when a friend invites me though.
    I am currently using a wireless router but the xbox is connected by a cable and the pc is wireless.
    I have played these people before but they have hosted and due to lag I wanted a rematch with me hosting.
  6. -Jay-
    -Jay-
    Jul 26, 2002
    4,934
    Kop End
    +135
    When he accepts your invite you are pressing A to let him in yeah?
  7. Dogma21
    Dogma21
    Feb 4, 2005
    381
    Leeds
    +16
    not sure I'll try it and see how it goes.
  8. stevie p red
    stevie p red
    I have exactly the same problem as you .
    My friend (both new to online gaming )rang me to say he was online on PES4 .
    We added each other to our friends list via the xbox live screen .
    But going into the game ,we could send each other invites but when accepted ,nothing would happen .
    I created a game like you did and invited him off my list to no avail.
    What is the player list ?? He had different people in his ,than mine at the same time .??
    Please some body must have a solution .
    Steve P
  9. harrist0
    harrist0
    Feb 10, 2005
    291
    16
    London
    Can either of you connect direct to your modem rather than go through a router. This usually solves the problem. Otherwise there will be no other way as i also have the same problem and there is no way around this other than not using a router.
  10. stevie p red
    stevie p red
    i connect direct with an ethernet cable ,but he has a wireless router.
    Do you reckon that is the problem
  11. harrist0
    harrist0
    Feb 10, 2005
    291
    16
    London
    Yeah i think so. You can try connecting without your router as that might work.
    I had problems with this whilst in the PSE4 av tournament and that was the suggestions that were given by me by all the other players so i think that's where the problem lies. I think someone said it was incompatible routers therefore this solution should work. Let me know if it does.
