Axuss
Hello!
I have made this "Need help with new Game PC build" thread because I was searching for a forum where people could help me with my new Gaming Rig build. To give a bit of side information, I have quit a very expensive hobby (motocross), I sold my bike and all my gear and I want to spend this money on a new hobby that I have as of now, which is gaming and my pc in particular. I have a budget of 7000 euros max to utilize. I will be gaming in 4K, video editing, and using photoshop.
I would like to include these parts already into the build:
The question I have about the graphics card is, what is the difference between the RTX 4090 models and the Strix one? There are so many different variants of these cards that I don't know which one to choose. I am also terrified that my cable will melt because of the known problems it gives. I found this cablemod website which should fix it but I don't know if its a safe option. ** MOD Edit, link removed **.
I also wanted to ask if this motherboard is a good option and if it has a good sound card or if I should get a separate one. About the storage I am still waiting for the PCIe 5.0 ssds that will come out soon as the motherboard supports it and if the motherboard is a good choice. Because I want to have a lightning-fast PC. I have also seen that the motherboard supports 128 GB RAM, which I would like to have as well but if 64 GB of RAM still is enough for what I'll be doing that is fine too.
As for the cooling, I will ask the company where I am going to buy it to let them install a custom water cooling system with tubes etc. Since the CPU and GPU need a lot of cooling. Or is aircooling enough? Because I would like to have a quiet system that has no problem cooling my system.
One last question, should I go with windows 10 or windows 11?
That's all the information I have gathered from my side. There is so much information and I get so confused and lost in PC building. Because of this, I wanted to ask for your help since I am a total noob at this. Could you guys help me build a next-gen high-end gaming rig that utilizes my budget?
If you guys require any further information, let me know!
I want to thank you all in advance and considering reading this topic.
- Intel Core i9-13900K 3 GHz 24-Core Processor
- Asus ROG MAXIMUS Z790 HERO ATX LGA1700 Motherboard
- RTX 4090 Graphics card
