Heugatter
I'm new to Smart TV Box's so my apologies if I sound dumb.
It's stats are: Amlogic S905W android 7.1 ARM cortex a53 C 4 CPU 64 bit GPU 5 core MALI-450
LAN 100M WIFI 2.4G IR Dual.
Now, I installed it with the plug n play instructions and did the setup which was a challenge just figure out the remote. I've got it working (sort of). It came with KODI pre installed and when I go into KODI to Exodus to get to movies and TV, it give me a message that says: No stream available.
I also found that I was able to get one TV program via the search last night, but today can't get it.
On a lot of the lists ie, genre or movies when I click on them it just gives me the search thingy and then stops and returns to the list. What do I need to do to get this thing to work? Any info will be appreciated. Thank You
