need help with Loewe Calida
Discussion in 'General TV Discussions Forum' started by bishop_2, Jul 13, 2002.
  1. bishop_2
    bishop_2
    I recently purchased a Calida 5684. I think it is a 98 model. Anyway, Unfortunately I didn't recieve a manual with it. I downloaded a pdf manual from the loewetv website but it is for a newer model. My remote control is different from the one that are shown on the loewe websites and in the manual (possibly an older model). In any case, for example, I cannot set the PIP buttons, instead for one of the PIP buttons I get a freeze frame. There are other buttons which don't seem to do anything so if someone can point me to a manual or even just help me with a few buttons I would be gratefull.
    Thanks in advance.
    Bish.
  2. bishop_2
    bishop_2
