J
jpslotus
Hi Guys, New to this so need a bit of help, I am intending building my 1st HTPC and am not sure about which components to order.
For starters I'm very keen on the Zalman HD503 for the case and would like to use Windows 7, also I would like to retain the Harmony 555 remote that I'm currently using. The HTPC will be used for playing Blu Ray discs, storing and playing SD & HD movies and music, I would also like to record TV shows with it and use the internet via my wireless router.
I have no intention of using it as a gaming machine.
It will be connected to my Onkyo TX-SR507B 5.1 amp and Toshiba 42" LCD.
Any advice would be very much appreciated.
