Need help with Denon 3313
AlvaroHenderson
Hi, my daughter touched the volume , it increased too much and now the device can t turn on. Is there a protection that can be operated or should i take it to replace some part (condensation problem maybe?)
Some advice? thank you!!!
dante01
Is the power indicator light flashing? This would be an indication that the receiver has gone into protection mode. This can mean it managed to prevent damage from occurring or it can be an indication that damage was done to internal components.
Unplug the unit from the mains and leave it for an hour before attempting to power it back up. If still in protection mode then you need to try a factory reset:
While still in standby, hold down the standby button whilst also holding down the INFO and the back button on the front of the receiver. Once the display starts to flash then you can release the buttons.
If this fails then you've incurred internal damage and you need to get an electrical engineer to look at the unit.
