could some1 plz tell me how to delete a file i had edonkey2000 installed on my pc but decided to uninstall it which went fine but afterwards in my prog file it left a temp file with 2 other files whithin the prob now is i cant delete these files when i try it says" cannot find the specified file" "make sure you specify the correct path and file name"what i cant understand these are empty files with nothing in it so how can i get rid of please
Try deleting the files from a command shell, rather than Windows Explorer - I've had similar problem and that's always worked for me.
