Need help with connection problem!
Discussion in 'Cables & Switches' started by Quicksilver25, Sep 13, 2005.
  1. Quicksilver25
    Quicksilver25
    Oct 30, 2001
    99
    9
    uk
    Hi guy's,
    Iv'e just taken delivery of a new digital audio cable 1694A (belden)
    to replace my optical cable connecting my pioneer 575 dvd player to my kenwood KRF-V5050D.
    When i removed the optical and connected the digital coax i got no sound!? :mad:
    I connected the cable via coax out (dvd player) and digital in,dvd,(amp).
    I disconnected the coax and reconnected the optical and it worked fine again?
    Iv'e looked at the manual and settings but can find nothing wrong.
    Am i missing something obvious or is there a bigger problem?
    Cheers,
    Q. :(
  2. Troon
    Troon
    Apr 28, 2005
    151
    Do you need to tell your amp which input to use?
  3. Quicksilver25
    Quicksilver25
    Oct 30, 2001
    99
    9
    uk
    Not that i can see in the manual.. any more ideas guy's?
    Q. :confused:
  4. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,305
    +100
    check the DVD manual maybe you have to select output type. Sometimes they need to be disabled when not in use to avoid potentialy dangerous noise output.
  5. Quicksilver25
    Quicksilver25
    Oct 30, 2001
    99
    9
    uk
    :thumbsup: Sorted it guys! :thumbsup:
    :thumbsup: :thumbsup: :thumbsup:
    Cheers.
    Q. :smashin:
  6. loadsofleads
    loadsofleads
    Isn't it a glorious feeling when you get that equipment to sing, better than sex in many ways :rotfl: :rotfl: :rotfl:
