Need help with buying a plasma tv
Discussion in 'Plasma TVs Forum' started by plauz, Nov 8, 2004.
  1. plauz
    plauz
    My father's thinking of buying a new tv and it would be a plasma tv.
    It would be in pricerange 2000-3000€.
    The 2 models I consider buying are:
    LG RZ-42PX11
    PHILIPS 42PF9946/12
    I've chosen these 2 models because they have a pretty large screen for that price. Are these good models and which model is the best? I know nothing about the specs. Please tell me some pros and cons about these tvs.
    Are there other tv's you'd suggest to buy in this pricerange?
    And what other models are good in this pricerange: http://www.vandenborre.be/ECOM/app/ECOM.vdb?Np=MmqaSuabYN0lceKabu9k#
    If the models with the same price but smaller screen really have better picture quality I consider buying one of them.
    Which model(s) is/are the most popular at the moment? Price/Quality?
    Thanks a lot.
  2. sparrer
    sparrer
    Plauz,
    It seems that unless you mention the magic word "Panny" in this forum , you don't get any response . Good luck
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    Calm DOWN personally i would reconmend the PAnny TH-42PA30 TV but what are you after and where are you there are some french members who it may be worth speaking search for thread by peezee and theirfeu who are debating this currently
  4. sparrer
    sparrer
    I rest my case.......
