Need help with Aill-In-One...please
Discussion in 'Home Cinema Buying & Building' started by Caimbeul, Jun 13, 2005.
  1. Caimbeul
    Caimbeul
    Jun 7, 2005
    734
    Kent
    +25
    Hi ,
    Does anyone know of a good A.I.O. system that can all of or most of the following?
    HDMI + Prog scan/HD compatible component
    Active Sub
    5.1 or better
    DVD upscaling to 720p
    mpeg4/divx/xvid etc playback
    enough inputs for 3 consoles (preferably connections that accept 5.1 signal)
    I initialy thought of the Samsung HD950 + Denon AVR-1905 but I would have to buy a speaker package maybe the Mordaunt-short Avant Premier Plus but this hugely bumps up the price (total=approx £900) which is more than i would ideally like to spend only due to the other being likely to murder me should I spend such a figure.
    I currently have a Panasonic SC-HT75 which is good little system coupled with my 28 Wega (CRT). IF, as an example, I went for something like the Denon 500SD, which doesnt have a huge amount of the features that I require (listed above) would the picture & sound performance increase be very profound between the two systems? - I am looking to eventually hook all this up to a Samsung SP50L7HX DLP tv.
    Once again any help is greatly appreciated!! :D
  2. Caimbeul
    Caimbeul
    Jun 7, 2005
    734
    Kent
    +25
    **BUMP**
    Ok, as nobody seems able to answer this maybe someone could answer this instead... :lease:
    Is it true that all HDTV's upscale? ie: if i was using a Denon 550SD as DVD source via component, would the picture be upscaled? or does it HAVE to go through HDMI/DVI to upscale?
    Thank you!
  3. Kefre
    Kefre
    it think it will take a few months for manufacturers to come up with a reasonably priced all-in-one home cinema kit with specification you are looking for. I have been looking for one, but no luck. so, I am going to settle for something with a component output and progressive scan.
