Need help with a Projector for 300 inch screen
Misfitwrx
Currently we have 2 1920x1080p projectors running with edge blend software (pro presenter) to achieve a 3840x1080 resolution at 32x9 aspect ratio on a 310 inch screen (298"x84"). We would like to move to a single projector to achieve the same result. we would need the projector to be 16 ft from the screen as well. any help would be greatly appreciated.
Stridsvognen
Take a look at The Christie Eclipse.
And SONY VPL-GTZ380ES.
Or the SONY VW 5000ES might be able to light up your screen if its a 1.0 gain or above.
Misfitwrx
The current 2 projectors we are using are Optoma WU515T and they are plenty bright enough for our use case. They are roughly 2500 a piece so i was hoping to find something in the 5000 dollar range if possible.
I think the tricky part is the 16ft distance from the screen. if we can move it back would this be a possibility? LG CineBeam 4K UHD Laser Projector (GRU510N) | LG USA
it says up to 300 inch screen
Stridsvognen
Try it, if you dont have any expectations to image quality most will work.
Podcast: The Best TVs of 2021, plus our favourite & memorable reviews of the year
