O
oreoboy13
I have most of it sorted.
The :
X-box
Ps2
DVD
travel by component to the amp and then via component to the TV
However i still have the Nokia on digi box, and that only supports scart/RGB and the amp doesnt have this capability, i dont really fancy using composite as its a 42" display.
I would just use the RGB and get round it using the pronto, however i dont think you can get discrete IR codes for the AV channels on the Toshiba.
Any helps or suggestions would be fantastic
Thanxz
The :
X-box
Ps2
DVD
Thanxz
