Need help understanding digital sound connections
Discussion in 'AV Receivers & Amplifiers' started by markyboy, Oct 28, 2004.
  1. markyboy
    markyboy
    Oct 7, 2004
    28
    I WAS planning to get a 32" Sony tv with a Panasonic DVD recorder AND a Sony home cinema system with built in DVD player (this seemed cheaper than buying a spearate amplifier)...... but a reputable LOCAL high street tv/hifi shop told me yesterday that if I had this arrangement then I would only get digital sound from the built in player and NOT the tv or dvd recorder. Can someone explain to me why. I was of the opinion that you just "connetced them all up" (probably via Scart leads) and away I went.
  2. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    It all depends on the connections on the Sony all in one. If it has digital inputs then you can connect the Panny dvd recorder to it and get digital input. You wont get digital from the TV unless you have sky or freeview as TV's are still analogue. Scart are also only analogue connectors to.
    How much where you going to pay for the Sony as if you are getting a Panny you dont need another dvd player:nono: For the money you might be able to get an amp and speakers thet out perform the sony by miles:D
  3. markyboy
    markyboy
    Oct 7, 2004
    28
    Thanks for the reply, but it now sounds (further homework done !!) as though i'm better off getting a separate amp. Apparantly they will have more inputs. So i'm now looking at the Sony HT SL series (40, 60 or 500). I HAVE got sky (am upgradign to Sky+ soon) and so will get digital sound via the separate amp. I planned to pay around £170 for the amp and speakers (a deal with the Sony KV32CS70 at John Lewis or local Sony shop).
