Need help - tricky situation, limited budget.
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Pezerinno, Jan 19, 2005.
  1. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,452
    71
    Southsea
    +69
    Hi, I need some help here. Ok here goes, I want the following:
    5.1 surround for movies
    5.1 surround for pc gaming
    Good stereo sound for music (of which will be player from the computer - AAC or someother files)
    Needs to fit in a small space and my budget is £1250 - this has to also include a DVD player (was looking at the Denon 1910)
    DVD player will be connected to my sharp 26" aquos TV via DVI
    I will be removing the sharp aquos speakers
    Music coming from pc via audigy 2 ZS soundcard and optical TOSlink cable, also want to use this for surround sound pc gaming.
    I need small speakers (ones that will go on the desk) but have plenty of room for amps and whatknot.
    My listening will probably be something like 50% music, 25% pc gaming, 25% TV/DVD.
    I've enclosed a room plan so you can see what sort of space I'm dealing with - I'm in halls of residents so lacking space.
    Can't order anything from creative-audio as they don't deliver to students halls of residents.
    So what should I get?
    Thanks.
  2. superkully
    superkully
    Sep 29, 2004
    48
    For the sources and size of your room, have you considered buying something like the Logitech Z-5500 + DVD player?
    A 5.1 setup would sound horribly muddled in a room with that size and layout (I used to have a room about the same size and 2 channel was bad enough). Perhaps better to go for a Toshiba 340e & the Z-5500 setup (or whatever) and save the grand or so for when you've got a proper room and the tech.\money ratio is even better.
  3. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,452
    71
    Southsea
    +69
    Funny you should say that as I was originally going to buy a toshiba 340e and logitech Z-5500 but then people started saying buy something better. Would the logitechs be ok for music & movies though?
  4. superkully
    superkully
    Sep 29, 2004
    48
    If you're playing ATRAC,MP3 & al you'll be more than happy.
    I really wouldn't even dream of spending £1250 on a room that size and with the furniture positioning unless you wash your back with a bundle of £50 notes on a stick... :)
  5. Pezerinno
    Pezerinno
    Dec 26, 2004
    3,452
    71
    Southsea
    +69
    I think i might still go for the Denon 1910 actually instead of the tosh as I have an expensive IXOS DVI cable and I don't believe the Toshiba takes DVI? Save me buying an expensive component cables.
    EDIT: do you know the cheapest place to pick up the Logitech Z-5500?
