Need help to make 963sa multi-region!
Discussion in 'Blu-ray & DVD Players & Recorders' started by Rusty, Feb 10, 2003.
  1. Rusty
    Rusty
    Hey, is anyone out there happy enough with their 963 to consider dropping by and helping me out with the multi-region thing? I don't have a pronto (did briefly consider it but all RS were sold out of course), or a one4all.
    I'm in Central London (near the City) so not exactly difficult to get to if you work there.
    richard@canoemail.com
  2. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
  3. Rusty
    Rusty
    Aha! Someone who can help!
    Since you can confirm that it works with the 963, could you post what exactly it was that you did with *this specific remote*, as I think I might follow your advice.
    Also, I presume that you used the supplied remote for the PAL-P hack?
    Thanks!
  4. kwangomango
    kwangomango
    Jan 9, 2003
    856
    Kent
    +38
  5. evans
    evans
    Nov 24, 2002
    1,161
    48
    +36
    rusty
    I got this from this forum as Im thing of buying this dvd player, is the picture any good?
    anyway:
    you have to hack the 963 for prog pal first, then the Multi region hack.
    Pal Prog + Multi Region hack for 963sa (R2 - Europe version)
    1. Hack for PAL p-scan using the supplied remote is "play", "159 222 023 00" , then press "play" for region 2 player
    2. Enter RC6 command via Pronto
    [[[For multi-region using a OneForAll (URC7560), to generate the RC6 code:
    2.1. The remote should be set up to control the DVD (setup code 0539).
    2.2. Press the DVD button.
    2.3. Press the Magic button.
    2.4. Press 085.]]]
    2.5. The display should read '----'.
    2.6. Enter the following with the normal Philips remote:
    [[On newer models, there appears to be 11 spaces in which to enter a code]].
    222 222 005 255
    The player should now be able to output pal progressive scan + be region-free
    buy and good luck
  6. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,804
    Hogsty End
    +70
    Hi there.
    Can anyone help me on how to generate the RC6 code with a Pronto? I don't have a Pronto, but will try using a ProntoEdit CCF with TVRemote.exe on my PDA.
    I can't actually figure out which is the RC6 code I'm aiming at!!!
    Thanks in advance,
    Joel
  7. evans
    evans
    Nov 24, 2002
    1,161
    48
    +36
    sorry m8 i ended up buying the philips q50 instead as it was cheaper, still have it and very pleased with it , great picture. :thumbsup:
  8. Kefmad Rich
    Kefmad Rich
    Feb 28, 2002
    178
    Edinburgh
    Hi Joel,
    Pm me and I,ll send you my Pronto CCF which has a Multi region code on it.
    I,ve used it on a few 963,s :thumbsup:
    Regards
    Richie.
  9. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,804
    Hogsty End
    +70
    Thanks Richie. You have PM...
