Need help Sony Bravia won't connect to virgin super hub
Discussion in 'Cable TV & Virgin Media TV' started by kenmackspuds, Oct 13, 2016.
  1. kenmackspuds
    kenmackspuds
    Oct 13, 2016
    2
    swindon
    Sorry if I have posted this in wrong place ?
    I have all my devices in house well connected to virgin super hub
    However when I try to connect my Sony Bravia it won't find the router ?
    No idea why
    Ssid and password which I use on all other devices won't work nor will wps
    Any suggestions ?
  2. metalguru
    metalguru
    Apr 4, 2005
    1,214
    Scotland
    +136
    What model tv and hub and have you tried with a cable?
  3. kenmackspuds
    kenmackspuds
    Oct 13, 2016
    2
    swindon
    It's virgins super hub2 made by netgear
    The tv is bravia kdl47w805a
    The hub is about 18 feet from the tv
    All other wifi enabled devices in the house talk well to the hub I.e. iPads , iphones etc
    I have not tried cable since all other devices are fine and don't see need to
    The TVs wifi is on but it wa
    Not find the router on any scan or manual input ?
  4. metalguru
    metalguru
    Apr 4, 2005
    1,214
    Scotland
    +136
    Is it a Superhub2 or a Superhub2 AC ? I'd try straight with a cable or using homeplugs, wifi is crap any way.
    Certain Superhub 2's had dodgy solder on the internal aerials, which caused problems.
  5. Clem_Dye
    Clem_Dye
    May 8, 2006
    3,520
    +531
    Might be that the TV only supports the 2.4GHz wi-fi network, and may be getting confused if you haven't split the two networks via the hub. As posted though, wi-fi just isn't a stellar way of connecting devices, and you should always use ethernet wherever you can.
  6. metalguru
    metalguru
    Apr 4, 2005
    1,214
    Scotland
    +136
    The Superhub 2/2ac and 3 broadcast both the 2.4 and 5 at the same time, the original Superhub you had to pick one or the other, that's why I was asking him which hub he had.
  7. metalguru
    metalguru
    Apr 4, 2005
    1,214
    Scotland
    +136
    But obiously he doesn't need any answers now by the look of it:facepalm:
