Need HELP - Sky+ to component via JS Converter.
Discussion in 'Sky Digital TV Forum' started by MillionDollar, Jan 18, 2005.
  1. MillionDollar
    MillionDollar
    Nov 13, 2004
    55
    I bought my kit before xmas, but have only just been able to install the plasma in my new house.
    Everything works fine except I can't get a Sky picture on the Plasma.
    I have been supplied with everything needed and was told to setup like this:-
    Scart from Sky+ box to JS RGB to Component Converter, Then component goes into my Denon amp.
    From Denon amp goes Component to VGA input on Plasma.
    Can anyone tell me where am I going wrong?
    the JS converter is showing a red light.
    my DVD is working fine.
    Please please need quick help :confused: :confused:
  2. John
    John
    Dec 13, 2002
    11,264
    +2,876
    What sort of plasma have you got ? Can you connect from JS direct to the screen.That would eliminate a problem with the JS box
    Also what sort of lead are you using to connect from amp to screen.
    Do you need to set the VGA input to recieve a conponent signal
    Atb
    JS
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    is sky+ set to RGB????are you using TV scart?
  4. MillionDollar
    MillionDollar
    Nov 13, 2004
    55
    Hi all thanks for your help I have got it fixed.
    The scart lead was in the wrong direction.
    The scart lead I have got is directional, which I didn't know.
    :thumbsup:
  5. Slartibart
    Slartibart
    milliondollar
    How much does the Js convertor improve the sky picture
    i am thinking to get one to run to my new HS50 Projector
  6. MillionDollar
    MillionDollar
    Nov 13, 2004
    55
    Unfortunatley I can't really answer that, becuase this is a whole new system, I can't compare it to the old.
    But I have read many good reviews about the JS Converter, saying it is the best etc. best people to ask are the people at AV-sales.co.uk phone them up and they will help you out.
    I can tell you my picture is great, no probs yet!
  7. Slartibart
    Slartibart
    thanks anyway
    i have just bought a load of new kit, but am still stuck with old pana sky box.
    Am toying with either buying a rgb > component conv,or a new SKy + box which would give me S video output,dont know which is best,anybody got any ideas?
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    for PQ, JS RGB>YUV is better IMO but sky+ does a lot more...........
  9. Slartibart
    Slartibart
    thanks hornydragon
    have just ordered convertor
    guy from av sales of same opinion as you.
