mmaeng2013
I decided to wire my house with ethernet cable to each of the rooms to reduce the number of devices on my wifi, also I have a few that require a LAN connection to work.
Currently I have a Netgear CM1000 modem running to a Netgear GS108 gigabit switch. The modem only has 1 ethernet port, which I connect to port 1 on the switch.
I was able to get my router working through the network switch by first plugging it directly into the modem and letting it start up and initialize. Once it is up and running I'm able to switch it over to the network switch and plug the cable going to the switch into the modem. The current issue I am having, which I believe solving will allow me to setup the rest of my devices, is that my PS4 doesn't want to connect to the internet unless directly plugged into the modem. I copied the settings from when it was plugged directly into the modem and manually set them, it still won't pull a connection.
Is there standard places to get IP addresses, the gateway address and DNS addresses?
