Need Help setting up 3802 + rel
Discussion in 'AV Receivers & Amplifiers' started by Imran_UK, Mar 14, 2002.
  1. Imran_UK
    Imran_UK
    Jan 27, 2002
    1,232
    Nottingham
    +29
    I have connected all the speakers up, connected a digital coax from my sony 900v dvd to the 3802 amp.
    Connected the Rel Q150e using a phono lead that came with it to the Amp, red phono from the sub to the sub connection on the amp.
    Lot of knobs on the back of the Rel, how do I set it up corrctly.
    Any other tips for the 3802 are also welcome.
  2. magking
    magking
    Jan 6, 2001
    380
    Norway
    Ok,. I have the REL Q400 and Denon AVC A11SR and the set up is pretty much the same.
    I have set all speakers to small in surround. The REL is set to mode two. Bypass internal crossover and use the amp for bassmanagement. I use the highlevel input aswell for stereo, direct and puredierct, as the front speakers are set to large in theese modes i have the crossover at the REL at 45hz( Thats were my fronts go below -3db).
    To set the levels correct you should use a SPL meter. But if you don't have a SPL meter, use some music u know well with bass and adjust the volume to that music.
    If you look at Home Cinema Choice main page, then select Articles, the choose Subwoofers in the subject line you'll get all the infortmation you need.
    Good luck.
  3. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,497
    magking has pretty much summed it up well.
    You can use either mode 2 or 4 to bypass the subs internal crossover when it is connected by the phono input.
    Also, as he says, connect up the high level (neutrik connector). This will work well for music as the Denon sends full range signals to the front pair in Direct mode (regardless off speaker setup).
    Normally set the sub crossover around 5-10hz higher than the lowest bass frequency your main speakers go down to (this is for the music setup) and adjust the high level volume control to suit you.
    The low level (phono) volume for movies etc should be set around halfway and then adjusted via the Amps Channel level adjustment (SW).
    Setting ALL speakers to SMALL and ALL bass to the sub will generally give the best results.
    To balance everything properly you´ll need a Sound Pressure Meter and a test disc such as AVIA or Video Essentials (if you dont have a disc yet use the internal test tones).
    AVIA is available here
    www.ovationsw.com
    Video Essentials here
    www.ezydvd.com.au
    Hope this helps
    cheers
  4. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    Out of interest, did you know that the DSP in the DENON remains active in Direct and Pure direct modes to keep the subwoofer active, even though full range is being sent to the mains? As far as i know, the STEREO mode does not send full range to the fronts if they are set to "SMALL".
    To defeat the DSP in the Direct and Pure direct modes, and the DSP is never fully switched off, you set the SUB to OFF in the speaker levels of the Direct mode. The Pure direct mode inherits this setting.
    I think the AVC-A1SR will fully switch off the DSP in this configuration.
  5. magking
    magking
    Jan 6, 2001
    380
    Norway
    That's correct i think, MarkB.
    Had the ame "problem" with my Denon AVR3300.
    Thats why i use the highlevel connection at the direct and puredirect modes, and sub to off. I used to have only the lov level connected and had to switch between mode 1 and 2 at the REL for music and movies. As you can imagene i got a little tired off that after a while and connected the high level as well.
  6. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    23,720
    2
    In a secret location with Jennifer Lawrence
    +10,722
    One good thing is to make sure you have told the Denon there is a centre speaker installed.
    Unlike what I did last night. Thought the sound was a bit crappy from the centre until I realised what had happened.
    Doh!
    Greg
  7. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    Good idea!
