need help = SCART > DVI-I cable
Discussion in 'Cables & Switches' started by fenomen, Sep 5, 2004.
  1. fenomen
    fenomen
    hi everyone,
    I desperately need SCART-DVI cable for my Sanyo PLV-Z2 projector. My DVD player has only SCART output (except composite and svideo, but no RGB output) so I want to use SCART connector for RGB output. And my projector: SANYO PLV-Z2 has a DVI-I input.
    I found DVI pin layout here,
    http://www.appian.com/support/trav_techinfo.html (at the very end of page)
    and
    SCART pin layout here,
    http://www.uusikaupunki.fi/~bgt/scart.html
    Are there anyone who has knowledge about electrics/electronics and can help me? How can I do this cable? (or at least where can I find it? 'Cause I searched the net very hard and I couldn't find a site that sells this cable)
    of course, I imagine that SCART R, G and B pins will be connected to DVI interface's R,G and B. But I know nothing about ground pins and blanking/sync/referance etc. Please help.
    thanks
    murats@rocketmail.com
  2. bobbypunk
    bobbypunk
    scart is analogue, dvi is digital so they are not compatible without an actual convertor!
  3. r4nd0m
    r4nd0m
    last post is not quite correct, with DVI-i it is possible to input/output a RGBHV (de-interlaced) computer signal input, but with DVI-D only a digital signal can be in/outputted.
    This does not help, but what you want is a video to DVI converter...have seen one at...http://www.cypress.com.tw
    r4ndom
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,714
    The Borders
    +3,077
    fenomen
    Your VERY unlikely to find a cable that's SCART (RGB+Composite Sync) to DVI-I - the sales potential for such a cable will be minuscule and DVI -I cables are not something your average DIY'rs going to rattle up of an evening.
    I'd suggest adding a JS Technology RGB2YUV converter to the SCART RGB output of your source and connect to the PLV-Z2 using a long set of YUV Component cables.
    Best regards
    Joe
  5. fenomen
    fenomen
    Joe, thank you very much for your help. And please let me ask a thing.
    DVI-I connection has analogue R, G and B pins at the plus shaped side of the connector. If I can link SCART's R,G and B pins to the DVI-I connector's R,G and B. Does it work? or should I link some another pins like C4-analog horiz sync. to somewhere? (reference from DVI pin layout here, http://www.appian.com/support/trav_techinfo.html (at the end of page)
    and of course, is this dangerous for equipments?
    thanks.
    Murat
    PS. I think. A you told me to use a RGB2YUV convertor and convert the SCART's RGB ignal to component. I guess you know PLV-Z2's component input1 socket. Right? You want me to use that input.
