Hello
I have been trying to save to DVD from TVDrive but have came across a few problems.
As the DVD Recorder said I tried to output from the RGB scart on the TVDrive. The problem with this is that this only recorded whatever was on the screen, plus I had to change the TVDrive settngs to RGB from HDMI which was a pain.
So I went back to the normal video output which allows you to watch somthing else as it records from your TVDrive recorded programs.
The enoying thing now is image quality. When it is recorded it dosnt all look that great. Im guessing that this is mainly because of the length of the programs against the length that DVD's allow.
What I am now asking is if anyone knows a way that I can get better quality recordings.
I thought maybe that I could pause the recorder during the adverts to shorten the length a little but it wont allow this.
Or is the quality difference not that noticeable really?
Any help will be great.
