Need help picking out a good shelf for my consoles and receaver
D3ltax5
As my collection grows, I need more room. I need a good sturdy shelf the can hold 2 consoles per shelf and enough room and strong enough to hold a receiver also.
I have a shelf that is 29 1/2 inch with with 5 shelfs. lucky enough it the hole ones and I made the shelfs spaced out how I want it. It's just the fact it's not really strong. and made with conductive thin metal made for holding household items. THe receiver is going to collapse the metal if I didn't put wood underneath the shelf to support the receiver on the bottom shelf. I want to upgrade this shelf thou. I got it from home depot here in Canada.
My I moved my tv stand off center cuz the length but Im used to it now.
D3ltax5
It ended up being way to much for each shelf. I got to find something else. Anyone know something similar?
Edit the non adjustable one's you get more then one but it will still run me alot of money. I may do it now if it's the best option. But I rather save the money if possible.
D3ltax5
Can't decide if 24" is good enough for 2 consoles side by side (comparing the xbox s and ps4 it's 23" right against each other.) ( I guess I should put the sega cd by self or get the smaller sega cd) If it was a inch or 2 wider would of been better. or should I just get 30" which is half a inch wider then the one I have now. Remember I don't have much space to work with and would mean everything is off center like my tv but that is what I am doing now, im used to it.
Wire Shelving Accessories - Acklands-Grainger, Canada
Are these the polls for it?
METRO POST CHROME 74IN - Wire Shelving Accessories - MPW74P | 74P - Acklands-Grainger, Canada
D3ltax5
Well I found something on amazon.
https://www.amazon.ca/SortWise-Adju...15533&sr=8-4&keywords=adjustable+shelves&th=1
Do you guys think the shelf them-self are adjustable to fit any space or are they fixed to certain height. If it's not fixed and can put them in any height i was thinking in getting the 3 shelf one also in the same link and take the shelf from that so I have more shelfs. Or I can get the one beside it with wheels that is wider about the same width I am using now and not use the wheels. (I will find something at home depot so it doesn't scratch the floor.
D3ltax5
Well I asked on amazon answers and they said it's sturdy and the shelf's can be in any place the stopper goes so every bump. Seems good to me now which one should I get the wider one or the one I showed first narrow one?
Similar threads
