need help philips plasma rgb denon 1910
Discussion in 'Philips TVs Forum' started by crazyasyoulike, May 9, 2005.
  1. crazyasyoulike
    crazyasyoulike
    I have (Philips 42PF9946/12 42" Plasma) (Denon DVD-1910) (Denon AVR-2105)
    I need help with the following, I have my cable digi box on the screen via the RBG scart, I need to connect my DVD to the screen, I want to use component RGB to my AVR then to the via component screen, but don't have any RGB inputs left. Can I some how convert it to 15pin VGA.
    If I can is the quality good?
    Will my screen support it?
    I am a real newbie and need help.
    thx , Dave
  2. crazyasyoulike
    crazyasyoulike
    I'm new here, i have look over a few posts, is this Dr John Sim someone who makes cables/converters? can he help me?
