need help people with file conversion
Discussion in 'Computer Software & Operating Systems' started by MV Owner, Aug 15, 2013.
  1. MV Owner
    MV Owner
    Jun 8, 2010
    Dear all,
    I have obtained footage from a racetrack security camera which I need 'cleaning up' to improve resolution and perhaps converting to a you tube vob file.
    the file has been supplied in a format called .pns, i would appreciate it if anyone knows of a free down load that may be able to help.
    cheers
    mv
  2. limblee
    limblee
    Dec 21, 2006
    2,155
    67
    Ruislip
    +235
    Have you tried the vlc player with the K-lite codec pack installed? I've that although not listed in the codec list the Pelco PEF file extension does work, Pelco PNS might !
  3. MV Owner
    MV Owner
    Jun 8, 2010
    hello, please can you expand slighlty on that resonse. i can view the file but am looking to increase the resolution
