Just hooked up the speakers to the schitt dac and preamp without sub. I'm surprised at how good it sounds and for music it almost doesnt need the sub (haven't tested speakers with sub until now). The dac is every bit as good as the Sabre on the cxa81 and I think it actually sounds quite a bit better with a more full sound, but don't want to fall into confirmation bias
as it could just be placebo and wanting to hear an improvement.
The Schiit items are very much loved by very many people from what I’ve read. I’m not surprised you find them very good indeed.
They are also tiny. Believe it or not that means an awful lot of money is saved buy the manufacturer and the buyer.
The biggest cost of an amplifier for instance is its chassis. Same for dacs and preamps.
Small chassis items have a huge cost advantage.
And Schiit, so far as I'm aware, are a direct seller, which means another huge saving. No dealer mark ups to inflate the price.
They therefore have an excellent base for building very high quality electronics at (from a traditional perspective) impressively low cost.
The CA is a totally different beast too. It is an integrated amplifier; with an added dac.
It’s not nearly the same category as the Schiit dac.
Using the CA as a dac preamp, it’s surprising how decent it is at that job, as that is not its design function.
The Schiit line of dacs and preamps may well be as far as you need to travel.
When funds allow, one of their better preamps on loan will let you see what they’re up to.
And if you find it makes the difference that it should then the same plan for their better dacs later would also seem a great idea.
I’m sure the speakers will thank you for it.
In the meantime, you’re clearly enjoying the set up, so I’d suggest you do that very thing for a good while.
Upgrades are all well and good, but it’s more important to relax and enjoy the new stuff, your music and films. Then when your wallet is full... anything goes
